Custom Blocks Using Expressions and SSM
Is it possible to use expressions within a field? The way my company sets up drawings, the elevations will almost always be on the sheet directly after a partial floor plan. I would like to put a field that uses SSM to add 1 to the current sheet number so that it references the next sheet without having to insert it manually. Is this possible? I am very new to CAD so please explain it simply.
Yes, it is possible.
First, using MText command, right click and select insert a Field, then choose Formula from Objects in the Field Names.
Next, in the Formula text box right click and again insert a Filed, this time choose the Current Sheet Number from Sheet Set in the Field Names.
After you inserted the Sheets Number in the Formula add 1 simply by typing +1
Then click Ok and you're done.
1 -
That worked, thanks. I was originally trying to insert the field (Sheet Set - Current Sheet Number) and add 1 from there. Copying that expression into the (Object - Formula) field and adding 1 worked perfectly. Our shop drawings will be much more automated now!
0
