Exclude specific objects from BIMSECTION generated view
Hallo
we are working with a store design and would like to HIDE specific object a Bim section generated plan. How can this be achieved ? If I turn off the layer, the paving pattern below will show as broken / interrupted because both floor and furniture have gone through hiddel line removal.
Can I create a new Bim section and select which Items are affected or shall I simply use Layer state property in bimsection and create a layer state with selected layers off ?
Thanks
Luca
Hello.
BIM sections don't allow the user to select the entities to be included in the 2D view.
Using the layer state property seems to be, indeed, the solution for this case.
