pb import IFC
Gilles
edited July 1 in BricsCAD BIM
Je ne parviens pas a importer certains fichiers IFC , avez vous des astuces?
  • A good idea post in English as well.
    I'm unable to import certain IFC files; do you have any tips?
    No ideas.
  • Hello.
    When importing IFC files, there are quite a few settings available, as described in the article linked below.
    https://help.bricsys.com/en-us/document/dialog-boxes/i/ifc-import-settings-dialog-box?version=V26&id=171032310410
    You could experiment with various settings, there could be one that works for you.
    Also, after using the IMPORT command with IFC files, there is a log file created in the folder of the original IFC file.
    This log file contains information about the importing process.
    You could check it - there might be some indication about what didn't work.
