pb import IFC
A good idea post in English as well.
I'm unable to import certain IFC files; do you have any tips?
No ideas.
0 -
Hello.
When importing IFC files, there are quite a few settings available, as described in the article linked below.
You could experiment with various settings, there could be one that works for you.
Also, after using the IMPORT command with IFC files, there is a log file created in the folder of the original IFC file.
This log file contains information about the importing process.
You could check it - there might be some indication about what didn't work.0
