Push/pull from area
After 25 years of AutoCAD experience I switched to Bricscad (v23).
I ran into a small problem. I used to use push/pull to give volume to a closed sketch drawn on the XY plane.
The area gives a highlight, so it looks to go good, but I can't give it volume.
I always need to make a boudary with BO, but this doesn't feel correct.
Any help please?
I use V27 but it looked similar in past versions.
I would activate and make use of the floating QUAD panel that offers you context sensitive Tools.
If you need this task repeatedly :You can activate the boundary option for Selections …..
Hover over a potential boundary until it highlights and start Solid Extrude,
just define extrusion direction with your cursor,
enter an extrusion value and hit Enter.BTW,
as I just recognise from the screenshot, Extrude Command does not seem to be included in Bricscad Lite Version (?) in case that's the problem.
