Push/pull from area
After 25 years of AutoCAD experience I switched to Bricscad (v23).
I ran into a small problem. I used to use push/pull to give volume to a closed sketch drawn on the XY plane.
The area gives a highlight, so it looks to go good, but I can't give it volume.
I always need to make a boudary with BO, but this doesn't feel correct.
Any help please?
  • zoomer
    edited 9:31AM
    I use V27 but it looked similar in past versions.
    I would activate and make use of the floating QUAD panel that offers you context sensitive Tools.
    If you need this task repeatedly :
    You can activate the boundary option for Selections …..
    Hover over a potential boundary until it highlights and start Solid Extrude,
    just define extrusion direction with your cursor,
    enter an extrusion value and hit Enter.
    https://help.bricsys.com/en-us/document/command-reference/e/extrude-command?version=V27&id=165079077245
    BTW,
    as I just recognise from the screenshot, Extrude Command does not seem to be included in Bricscad Lite Version (?) in case that's the problem.
