LAYCUR and AI_MOLC
Is in BC alternative to AutoCAD express layer tool: LAYCUR and AI_MOLC
LAYCUR: ...objects to be changed to the current layer
AI_MOLC: ...object whose layer will become current
  • Dear Juraj Matel,
    For AI_MOLC use SETLAYER in Bricscad.
    LAYCUR appears not to be available in BC7. But this simple lisp will do the trick:
    (defun c:LayCur ( / )
    (setvar "cmdecho" 0)
    (princ "\nChange entities to current layer: ")
    (command "_.chprop" (ssget) "" "_layer" (getvar "clayer") "")
    (setvar "cmdecho" 1)
    (princ)
    Regards, Roy.
  • Great. It works. Thanks!
