LAYCUR and AI_MOLC
in Other
Is in BC alternative to AutoCAD express layer tool: LAYCUR and AI_MOLC
LAYCUR: ...objects to be changed to the current layer
AI_MOLC: ...object whose layer will become current
0
Dear Juraj Matel,
For AI_MOLC use SETLAYER in Bricscad.
LAYCUR appears not to be available in BC7. But this simple lisp will do the trick:
(defun c:LayCur ( / )
(setvar "cmdecho" 0)
(princ "\nChange entities to current layer: ")
(command "_.chprop" (ssget) "" "_layer" (getvar "clayer") "")
(setvar "cmdecho" 1)
(princ)
)Regards, Roy.
0 -
Great. It works. Thanks!
0
