Visible/Hide toolbars with tool
Is possible to make tool in toolbar or command (lisp) which can make/ change visble status for toolbars?
Ie. LISP command "3Don", make vissible toolbars "Solid Editing" and "Isometric Views" and "3Doff" it hide. Or simple "3D" make visible or hide this two toolbars.
Juraj,
My understanding is that you want to know how to make toolbars visible or hidden. Here is a sample code:
**TB_GEOT_POLYLINE2
ID_GT_PL2 [_Toolbar("Polyline Tool Set 2", _Floating, _Show, 100, 150, 1)]
....// The above two lines defines a toolbar heading
To show the toolbar, the code is:::::: (command "._toolbar" "Polyline Tool Set 2" "_show")
To hide the toolbar, the code is:::::: (command "._toolbar" "Polyline Tool Set 2" "_hide")
Hope this helps.
Regards
Rakesh Rao
http://rakeshrao.typepad.com -
Great! This is exactly what I need. Thanks!
Howdy, Stranger!
