Bricscad (Linux) 11.3.13 BETA
Hello All,
A new beta version can be downloaded using the Bricscad (Linux) BETA download link.
This version includes fixes for status bar, lisp file dialog, unicode filenames...
Greetings
Tijs
  • Thanks,
    great to see the unneded titlebars gone!
    On the other hand, the crashes with partial menus (SR 29565) are not gone...
  • (bricscad:8923): Gtk-WARNING **: Unable to locate theme engine in module_path: "clearlooks",
    Gtk-Message: Failed to load module "pk-gtk-module"
    Segmentation fault (core dumped)
  • Hi Tijs,
    one question, this new version include an improved lisp engine? because, various lisp routines don't work in the linux version but they work in the windows version.
    regards
  • Hi, Jorge,
    unfortunately, the Lisp engine is not yet complete as the Windows version ...
    As we promised, it will come, with 99.9 % identical functionality as the Windows version - it is simply a lot of work left to do.
    There are not any technical problems anymore - so we think, that the completed Lisp engine will come over next monthes.
    Many greetings
  • I wonder if this version will allow us to finally be able to work quietly with files that containimages. So far it is a tragedy to do that. Purttoppo are a bit 'discouraged, but I do not think much interest. Now the Classic version seems to be being abandoned.
  • @Knut Hohenberg
    My mistake.  A fix has been made for this issue in our trunk, which led me to adding it to the Release Notes, but apparently I forgot to merge the fix into the 11.3.13 tag.
    I have removed it from the Release Notes.  The fix will appear in the next version.
    (trunk is where continuous development goes on, a tag is where versions to be published are stabilized)
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
