Bricscad (Linux) 12.1.9 BETA
Hello Linux users,
A new Bricscad (Linux) BETA is available, just in time to download, shrink wrap and put under the Christmas tree ;)
To download, use the usual Bricscad (Linux) BETA download link.
If you do not have BETA access, you can ask for it in a support request.
Kind Regards
Tijs
«1
  • [code][root@PC-Linux ~]# cd /home/giacomob/Scaricati/
    [root@PC-Linux Scaricati]# rpm -ivh Bricscad-V12.1.9-1-en_US.rpm
    Preparazione in corso...    ########################################### [100%]
       1:bricscadv12            ########################################### [100%]
    [root@PC-Linux Scaricati]# cd
    [root@PC-Linux ~]# exit
    logout
    [giacomob@PC-Linux ~]$ bricscadv12
    /opt/bricsys/bricscad/v12/bricscad: error while loading shared libraries: libGLEW.so.1.5: cannot open shared object file: No such file or directory
    [/code]
  •  error while loading shared libraries: libGLEW.so.1.5: cannot open shared object file: No such file or directory
    But I do have it installed in /usr/lib
    Using Ubuntu 10.04 (lucid) 64-bit
  • Ubuntu 11.04 - the Natty Narwhal on an Asus G74sx-bbk8.
    Nvidia drivers version 270.41.06(let me know if you need more detail.
    after downloading i did a rightclick and opened the .deb with Ubuntu Software Center.
    It errored saying,
    The installation of a package which violates the quality standards isn't allowed.  This could cause serious problems on your computer.  please contact the person or organization who provided this package file and include the details beneath.
    Lintian check results for /home/phrostie/Downloads/Bricscad-V13.1.9-1-en_US.deb:
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/ModelerGeometry.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/RasterProcessor.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/RecomputeDimBlock.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/RxRasterServices.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/SpaModelerGeometry.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/TD_Dwf7Import.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/TD_DwfUnderlay.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/TD_STLExport.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/TD_SvgExport.tx
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/bdm_module.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/bricscad
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libBrxGeo.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libDWFCore.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libDWFToolkit.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libDbConstraints.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libImagine.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libLGSConstraints.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libLicenseManager5.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libREDCore.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libREDOpenGL.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libSpaACIS.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libSpaPhlV5.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_AcisBuilder.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Alloc.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Ave.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_BmpExport.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Br.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_BrepRenderer.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Db.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_DbCommands.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_DbRoot.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Dwf7Export.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_DynBlocks.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_FtFontEngine.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Ge.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Gi.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Gs.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_PDFToolkit.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_PdfExport.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_Root.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libTD_SpatialIndex.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libW3Dtk.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libWhipTk.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libbcadtest.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libbdm_module.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libbmodeler12.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libbrx12.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libbrxhlrapi12.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libcadapp.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libcmdapi.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libcommands.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libdcl.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libflyoversnap.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libfreeimage.so.3
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libfreetype.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libgeometry.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libicudata.so.38
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libicuuc.so.38
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/liblim3d_sa.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/liblispex.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libodapp.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libpc3_ed.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libprofilemanager.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libpstyle_ed.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libpth.so.20
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libsds.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libtestapi.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libutils.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_baseu-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_baseu_net-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_baseu_xml-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_adv-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_aui-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_core-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_gl-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_html-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_propgrid-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_qa-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_richtext-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwx_gtk2u_xrc-2.8.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libwxgui.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libxerces-c-3.0.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/libzlib.so
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/profilemanager_app
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/pstyle_app
    E: bricscadv12: arch-independent-package-contains-binary-or-object opt/bricsys/bricscad/v12/tester_bdm_module.so
    at the bottom the options were Ok  /  Ignore and install.  I installed.
    first 2 runs crash after the 3D-> Finish on the start wizard.
    Still trying.
  • if i use 2D -> finish and it started fine.
    i went ahead and drew my profile, and converted it to a polyline.
    when i tried to switch back to 3D Context it Crashed to the desktop.
  • I can use the Direct modeling menu and it all works fine, but if i go to 3D Context it implodes every time.
  • from the rendering menu
    the render/tea pot crashes to desktop.
    the material editor opens, but when i try to create a new one it crashes.
  •  simplified chinese
    DWGdirect warning: Code page conversion is impossible because conversion table for "ansi_936" is missing.
    when double click the text to edit,it show as "\M+5B2C4\M+5C1CF\M+5B2D6\M+5BFE2\M+5BCB0\M+5B9A4\M+5BEDF\M+5B7BF"
  •  It is interesting that bricscadv11 also uses libglew1.5.
    Why can v11 find it and v12 cannot on the same computer?
  • About the package quality warning "arch-independent-package-contains-binary-or-object":  So far the Bricscad (Linux) deb installer has used the architecture field "all".  This is now changed to "any-i386 any-amd64".
    About the libGLEW problem: No 32 bit libGLEW is available on 64 bit linux systems, see v12 error while loading shared libraries: libGLEW.so.1.5.
    A new installer has been uploaded, with updated architecture field and 32 bit libGLEW included.
    About the 3D functionality:  3D rendering with hardware acceleration by the Redway rendering engine does not yet work in Bricscad (Linux).  Therefore none of the new V12 3D features was mentioned in the release notes so far.  However, many features will already simply work since they do not need 3D rendering, eg direct modeling.
    Kind Regards
    Tijs
  • I've been working around them, so it's all good. i'm just reporting back what isn't working.
    the 12.1.9-2 still gives me the quality error, but not all the text line errors if that makes sense.
    oh, one issue i meant to bring up before but forgot.
    the text/pull down menus don't load by default.  i have to right click in the menu area and select customize -> tool bars.  then after changing something it shows up.
  • I had a lock up a little earlier.
    I had been modeling an assembly.  everything was running great then it started to bag down and get slower and slower.
    I assumed my assy just had to many surfaces for my laptop so i went to turn off layers i didn't need on.
    i hit the tool bar for the layers and it just froze.
    I think it had a slow memory leak.  i had been running for a couple hours.  it just finally caught up with me.
  •  Unable to print.
    Using "_print" the print window don't open.
    Fedora 16 Gnome3
  • can't print either.
    i went to the page setup for the tab/layout and when i clicked on device to add one it imploded.
  • ok, it's not a major crash type bug, but still driving me nuts.
    when i'm editing a profile/polyline by dragging the handles, it keeps flipping to the next desktop.
    at first i thought it had crashed, but everything was still running right where i left it and i was able to finish the operation.
    but it does this every time and every time i have to flip back to the correct window.
    it makes it hard to build up momentum.  :D
  • tool bars only showing the first icon.
    it just started today.
    and once again there are no text pulldown menus unless i go in and use customize.
  • Using Ubuntu 11.10 everything looks fantastic!  menus, fly-outs, tool bars etc. Of course I'm a Linux newbie : |
    sorry the screen shot is with dual screens : )
  • Cool screen-shot.  i was worried about upgrading.
    another one i keep forgetting to post.
    my preferred tool bar set up is with draw and snaps on the left and dims + solids edit on the right.
    but it won't let me put dimensions or solids on the right.
    it puts them on the left anyway and shoves my other tool bars off the screen.
    also i don't use View, but no matter how many times i turn it off/close it, it always there the next time i start up.
  • Hello,
    I'm just trying BricsCAD 12 Beta on my Ubuntu Linux (64-bit).
    Works nice, but:
    1. Why ECW image files does not work? Only image border appeared on the screen, but without image inside.
    2. Do you have plans for 64-bit native version of BricsCAD? (this question is for both OSes, Win and Lin)
  • Good day,
    Today installed it and cant run in 3D mode. From command line it returns a "Segmentation fault".
    Kernel: Linux 3.0.0-15-generic #25-Ubuntu SMP Mon Jan 2 17:45:26 UTC 2012 i686 i686 i386 GNU/Linux
    nVidia driver: 290.10-0ubuntu1~oneric~xup1
    With noveau 1:0.0.16+git20110411+8378443-1 Redway sdk complains
    Any trick available ?
    Many thanks!
  • I've had the same problem.
    you can start it in 2D and model in 3D.
    but the 3D Context mode will crash me every time.
    the Quad still works.  the Direct modeling menu still works fine.
    on the rendering menu, the tea pot will crash me every time, but most other options work.
    for me it's a bit of a mine field, but the direct modeling menu still makes it an improvement over V11, and i really liked v11.
    so i hope they can work through enough of these to release a V12 soon.  my beta only has 3 days left.
  • I miss to advice that have 2 OS in the same PC ( Ubuntu 11.10 and XPsp3)
    In XP work flawless but in Ubuntu, the 3D modeling crash. (I have had to install winXP for Bricscad v12.)
    My VGA is:
    03:00.0 VGA compatible controller: nVidia Corporation ION VGA (rev b1) (prog-if 00 [VGA controller])
        Subsystem: Foxconn International, Inc. Device 0d52
        Flags: bus master, fast devsel, latency 0, IRQ 11
        Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
        Memory at e0000000 (64-bit, prefetchable) [size=256M]
        Memory at f8000000 (64-bit, prefetchable) [size=32M]
        I/O ports at dc00 [size=128]
        [virtual] Expansion ROM at fafe0000 [disabled] [size=128K]
        Capabilities:
        Kernel driver in use: nvidia
        Kernel modules: nvidia_current, nouveau, nvidiafb
    Thanks a lot for your big efforts to bring the best cad solution to Linux. Many thanks.
    Regards!
  • I thought i remembered reading that the render engine used for 3D mode isn't running in linux yet.
    so the rendering that is used in 2D mode will let you shade/HLR in different modes, it just won't let you render material finishes.
    fwiw, Nvidia 560M / 32 bit Ubuntu 11.04
  • Hi Keith,
    I cant launch "3D Context", so i suppose that maybe the http://www.redway3d.com/pages/redsdk.php is not working properly in linux.
    Dont know :(
  • hmm,
    Their site says they have support for both Nvidia and ATI.
    They support Linux, but specify Fedora.  I think most of us are running either Ubuntu or Debian.
    Anyone running Fedora?  I'd be interested if this works on a Fedora box.
  • I can't show anything i do at my day job so this will have to do.  it was done for fun for a friend.
    yes, it's a lightsaber(don't laugh too hard).
    Enjoy.
    it's a small assembly, but yes it(Linux V12 Beta) can do 3D without 3D mode/3D Context.
  • Realistic rendering using RedSDK does not work in Bricscad (Linux) 12.1.9, regardless of used hardware or driver.
    Due to openGL initialization problem, the RedSDK hardware rendering crashes while loading its dependencies.
    For that reason none of the new 3D features was mentioned in the Release Notes of Bricscad (Linux) so far.
    Although many of the new 3D features work without realistic rendering we prefer to present them together.
    Redway has meanwhile fixed the openGL initialization problem, we should be making progress soon.
    @Keith Frost: Nice shots, great to see Bricscad (Linux) in use for real work ;)
  • my beta has expired.
    will there be a new one anytime soon?
  • first impressions of 12.1.14-1 are pretty good.
    upside:
    no errors or warnings on install.
    starting in 3D mode or switching to 3D Context didn't crash it.
    I get the grid/checker board to show my working plane while in 3D Context.(thank you)
    I was able to go into materials and create and edit a material.
    Quad is running a little smoother.
    downside:
    I didn't notice any difference in rendering or hardware acceleration.
    the gradient background i see in the tutorials isn't there.(yes i know it's nick-picking).
    even after creating and applying a material, my part doesn't look any different.
    I still don't get a text menu across the top unless i go into customize.
    on a side note, where do you set the color for part edges.
    the tutorials show dark edges, which i like, but i can only get white edges(when i use Gouraud + Edges)
    div>
    blockquote class="Quote UserQuote">
      downside:
    [snip]
    /quote]
    There appears to be a thread timing issue during start up. I use a relatively
    slow processor (Intel Atom D510 with 1.6 GHz dual processor) and it seems
    that the menu structure code needs time to initialise before another thread
    tries to populate the menu.
    The work around provided by Tijs for version 11 still works for version 12 beta:
    1. At the Bricscad command line type 'set' and press enter.
    2. At the prompt for 'Variable name or ? :' enter 'qaflags' and press enter.
    3. At the prompt for 'New current value for QAFLAGS (0 to 32767) <0>:' enter '16384' and press enter.
    4. Exit from Bricscad and start it again.
    5. The start up sequence of screen changes will begin.
    6. Part way through, you should see a sequence of four Menu Diagnostics alerts with varying length lists,
    7. Click on the OK button to dismiss each alert in turn.
    8. The remainder of the startup sequence will complete and the top line menu should be on display.
    If this does not work, please be sure that your system configuration
    Settings -> Program options -> Display -> Auto menu loading is ticked.
    If the above conditions fail I suggest you file a support request for official help.
