SWEEPX, LOFTX, SSBS (SliceSolidBySurface) commands to SWEEP,LOFT Solids+Surfaces, Slice Solids by Su
Very Impressive! I am curious to see a screen shot of one of your architectural projects if that doesn't infringe on any agreements - It looks like this would be very useful for funky stair designs...0
Hi Scott,
it is not "pure architectural", but it shows the "cutting" of a road within
a landscape in order to develop a settlement...
To do it in Bricscad you need a SWEEPX for the road and SLICEX for the landscape command !
The second example is the conceptual alternatives for the roof design.
You need a SWEEPX for the building and LOFTX for the roof forms
Regards
roof2.jpg0 -
A small bug in UNIONX is now corrected !0
with the new version 12.2.9-1 an error message is produced ....
so a new version is now available !0 -
Dear Konstantin,
a previously applied fix for property names was mistakenly reverted in V12.2.9.
Affected property names are: AllowDuplicates, RejectObjectsFromNonCurrentSpace and RejectPaperspaceViewPort.
The fix has been reapplied and is included in V12.2.11 which is about to be released.
This means that users of your application will not need the new version you just created.
We sincerely apologize for the inconvenience caused.
Hans De Backer
Development manager Bricsys0 -
Dear Hans,
many thanks for your response and informations !
...waiting for V12.2.11...
Best Regards
Konstantin0 -
just released...0
OK !
version SweepX-LoftX-V2-bc12.2.8-1.dll or the new one SweepX-LoftX-V2-bc12.2.11-1.dll can be used !0 -
The Package is updated for V12 and V13 !!!
2 new commands are added : EXTRUDEX, THICKENX
Please read the updated documentation for all commands .
As always your feedback is appreciated.
Enjoy !SweepX-LoftX-V2.2-bc12.2.18.dllSweepX-LoftX-V2.2-bc13.1.7-1(2).pdfSweepX-LoftX-V2.2-bc13.1.7-1.dll
0 -
That's cool! I can't wait to try it tonight at home!0
0
Thanks Konstantin !!
Regards
Paola0 -
Hi Konstantin,
I can't load your app, this is error message:
Error Message: Could not load file or assembly 'file:///C:\SweepX-LoftX-V2.2-bc13.1.7-1.dll' or one of its dependencies. Operation is not supported. (Exception from
HRESULT: 0x80131515)
Best Regards
Lorenz0 -
Hi Konstantin,
Best Regards
LorenzIt could be one of the new security features in .NET 4.0. Right click on the DLL, and choose "unblock"
Dan
0 -
Hi Konstantin,
Best Regards
Dan
0 -
SweepX-Unblock.png0 -
Got it, it's locked !!
Thanks to all !!
Best Regards
Lorenz0 -
Hello Bricscad Folks,
...just coming back online from a business trip....
Many thanks to Jason and Paola for their nice words.
Paola i am glad to hear that you still use the software!
Daniel thanks for solving the problem of Lorenzo.
I hope you enjoy using the commands and appreciate your feedback !!!
Regards0 -
hello konstantin,
real good programm. we need this tools every day in bricscad. Is it possible to get it in V13 ?
Please contact me per Email. info@ant-ares.de
greetings0 -
div>
blockquote class="Quote UserQuote">
Hallo Andreas,
du findest diese Software für V12 + V13 + Handbuch.pdf oben bei Position #41 dieses threads
Danke für dein Interesse
Gruß
Konstantin0 -
Hi Konstantin,I can't load your app, this is error message:; ----- Error around expression -----(CACHE BUG FOR BOOKMARKS IN FIREFOX);; error : no function definition ; expected FUNCTION at [EVAL]Regards,Hsiao0
Hi Hsiao,
How are you trying to load the application ?
What version of Windows and Bricscad are you using ? ....W7....B12 ..or B13
I am having no problems using W7 x64 and B12 or B13.. english !
Regards
Konstantin0 -
Hello Konstantin,I tried with V12.2.18 and V13.1.12, W7 x64 and XP w32.My CAD and OS all are traditional Chinese version.Regard,Hsiao0
Hsiao,
Using the command NETLOAD ?0 -
Konstantin,
Finally got around to trying out your 3D apps in V12 and the loftx works like a charm! Can you tell me if any of the commands will let you extrude a profile or solid to another surface? An example would be to extrude a pipe or cylinder to the outer dia. of a larger tank. Is this possible? Thanks for sharing the commands!
0 -
Hsiao,
Using the command NETLOAD ?Hi Konstantin,This is error message:: NETLOADLoading .NET runtime v4.0.30319:Error Message: Could not load file or assembly 'file:///C:\Documents and Settings\VPC\Desktop\SweepX-LoftX-V2.2-bc13.1.7-1.dll' or one of its dependencies. The module was expected to contain an assembly manifest.0 -
Hi Konstantin,It solve after the re-download the files.Regard,Hsiao0
Konstantin,
Hsiao,
you can't directly "in one operation" loft a profile to a surface using the LOFTX command.
You can do it following these steps :
1. Loft the profile using a path curve ending outside the cylinder or tank solid,
so that the end face of the lofted solid is completely outside the cylinder or tank !
2. Using the EDGEX command on the tank or cylinder solid you get ALL faces of it as surfaces !
The EDGEX command is NON DESTRUCTIVE meaning that the original solid remains ! (it is neither exploded nor deleted)
3. Using the SLICEX command you can now slice the lofted-pipe solid by the outer surface of the cylinder or tank.
You delete the ouside part of the lofted-pipe solid and there you are ...!
The pipe "is quasi extended" to the outer surface of the tank.
You can automate steps 1-3 using Autolisp scripting :
(defun c:ExtendSolid2Surface ( / tank e2sol)
(setq tank (car(entsel "Select Tank :")) ;the outer surface of the tank !
e2sol (car(entsel "Select LoftedPipe :")) ;the lofted pipe
(command "SLICEX" e2sol "" "S" tank)
Hope this helps
Regards
Konstantin
0
