SWEEPX, LOFTX, SSBS (SliceSolidBySurface) commands to SWEEP,LOFT Solids+Surfaces, Slice Solids by Su
Sorry Tim for the wrong name (...Hsiao) !0
Konstantin,
Thanks for the tip but what about using the extrudex command? Reading the pdf instructions it says this can extrude a profile to a solid/surface however upon trying it there was no option given to select a solid/surface to extrude to. Perhaps I'm missing something or maybe that feature hasn't been added yet.
Best Regards,
Tim
0 -
Tim,
the EXTRUDEX command does what it says...
...."The command extrudes a selection set of curves to a solid or a surface"......
it simply creates extruded solids AND SURFACES (not available in Bricscad 12 or 13) from given profile curves.
The native command EXTRUDE creates extruded Solids ONLY !
This was the purpose of creating this command.
What you want is to create an extruded solid/surface EXTENDED to a given surface !
It's just a matter of linquistic interpretation....
Regards
K.0 -
Hi Konstantin,
I am using Bricscad V12.2.17 and i had downloaded the SweepX-LoftX-bc12(3) DLL file and as per your instructions i gave command LOFTX but it pops up with an error message dialog box, please see the attachment for error
Sweep_Lotf.jpg0 -
Hi Sanjay,
you are using the oldest version from 16.12.2011 !
Please download the latest version at position #40 of this thread and try again
Let me know if it works
Here is a screenshot where to find the version...just scroll up to this position
Regards
B12-40.jpg0 -
Hi Konstantin,
As per your instuctions i downloaded the latest version but that shows loading error please see the attachment.
Sanjay.
NetLoad Error.jpg0 -
Hi, you might want to look at post #46 in this thread..
Cheers,
Dan
0 -
Hi Sanjay,
like Daniel suggests, the reason and solution for this error
is a different one explained and solved by #46 above ...
Thanks Daniel !
Regards,
Konstantin0 -
Hi Konstantin !
I plan to switch to x64 within few weeks, Your wonderful tool will work also on x64 ??
Thanks again and again !!
Paola0 -
Hi Paola,
the tool works already with x32 and x64 !
You find a new version (x32 + x64) attached compiled with the latest libraries for ver. 13.2.6-1
You can test it by downloading the trial x64 version of Bricscad.
What are you designing with the tool ?
Please report any problems.
Regards
Konstantin0 -
HiCan you please explain in a step by step (cook book style) how to load the lofting and sweep functions and how I can access these commandsMany thanksJohnC0
Hi John,
1. for Bricscad V13.2x (32 or 64 bit) download the version at #71 of this thread SweepX-LoftX-V2.2-bc13.2.6-1.dll
2. for Bricscad V12x or V13.1x download the versions at
https://forum.bricsys.com/discussion/17053#19297
SweepX-LoftX-V2.2-bc12.2.18.dll
SweepX-LoftX-V2.2-bc13.1.7-1(2).pdf a PDF manual explaining the Function and Use of the commands
SweepX-LoftX-V2.2-bc13.1.7-1.dll
3. In the command line of Bricscad load the respective .DLL using the NETLOAD command
4. then call the commands in the command line of Bricscad by typing their names LOFTX, SWEEPX, SLICEX etc......
and read the manual PDF
I hope this helps !
Regards
Konstantin0 -
HiI am obviously doing something wrong as I still can no get this to workPlease see attached doc - I have aslo tried the un block option - without successWhat am I doing wrong ?Thanks in advance0
Hi John,
YES the your last message tells that the file is not recognized and loaded ....
i have just downloaded the the version at #71 of this thread SweepX-LoftX-V2.2-bc13.2.6-1.dll in a directory (...say c:\test\...) on the local drive C: of my computer.
I tried to netload it and could not because the file was blocked !
I unblocked the file and could not still netload it !
I had first to quit (exit) Bricscad 13.2.8 and run it again !
NOW the file loaded and could use the commands (LOFTX etc..) without any problems !
So the file is OK !
Please follow again the steps :
1.
download the file SweepX-LoftX-V2.2-bc13.2.6-1.dll in a local directory on your LOCAL drive, NOT on a network drive !
2.
Unblock the file BEFORE you run Bricscad !
Make sure it is unblocked by going again in the Properties Tab....
3.
Run Bricscad and NETLOAD the file...
Now it should work ...0 -
Hi John,
looking at your last message again, i think that the problem might be also
the .NET Framework and Runtime installed on your computer.
Please install the .NET framework again.
For Bricscad V13x from
http://www.microsoft.com/en-us/download/details.aspx?id=17718
For Bricscad V12x from
http://www.microsoft.com/en-us/download/details.aspx?id=21
0 -
Konstantin - Hi - Many thanks - All Good - It is working for me -
Regards
JohnC0 -
Hello Konstantin,Support V14 yet?0
Hello,
according to my tests the existing version for V13 works for V14 as well.
Unfortunately due to problems/bugs in the C# .NET Functions sol.CreateSweptSolid() and surf.CreateSweptSurface()
the SWEEPX command doesn't work with 3D splines OR 3D polylines as sweep path in the V14 of Bricscad !
I have placed a support request since Sept. 2013 but have not received any feedback until now. I am looking forward at getting a response.
Till then please use the built-in SWEEP command for 3D splines OR 3D polylines as sweep path.
Attached you find the version for V14.1.13
If you find problems with any of the commands please report them.
Best Regards and happy 2014 ......for all in this Forum !0 -
Hi Konstantin,
loading SweepX-LoftX in my BricsCAD V14.02.06 PRO with "netload" (in my German Edition "netla") following Error-Message:
NETLA
Error Message: Die Datei oder Assembly "file:///C:\SweepX-LoftX-bc_14.1.13.dll" oder eine Abhängigkeit davon wurde nicht gefunden. Der Vorgang wird nicht unterstützt. (Ausnahme von HRESULT: 0x80131515)
; ----- LISP : Call Stack -----
; [0]...BRXLOADMANAGEDDLL <<-- <br> ;
; ----- Error around expression -----
(AL_EXECUTEADSDEFUN "BRXLOADMANAGEDDLL" REST)
; error : SDS request returned error at function : BRXLOADMANAGEDDLL
Das modul E:\SweepX-LoftX-bc_14.1.13.dll konnte nicht geladen werdenThe same Error-Message if the file is in the local drive "C:"
My System: win 8.1 64bit
I hope you can help me to get run SweepS + LoftX
Best Regards!
Hannes
0 -
Hi Johannes,
try the new attached version compiled for 14.2.6.-1 (current version).
Let me know if you still have the problem...
Regards0 -
Hi Konstantin,
thanks for your quick answer, the Error Message is a little bit different:
: NETLA
Loading .NET runtime v4.0.30319:
Error Message: Die Datei oder Assembly "file:///C:\SweepX-LoftX-V2.2-bc14.2.06-1.dll" oder eine Abhängigkeit davon wurde nicht gefunden. Der Vorgang wird nicht unterstützt. (Ausnahme von HRESULT: 0x80131515)
Das modul C:\SweepX-LoftX-V2.2-bc14.2.06-1.dll konnte nicht geladen werdenBest Regards!
Hannes
0 -
Hi Johannes,
i think the problem is that the .dll is locked !
The problem is stated in messages #45 #46 # 47 above in this thread...
Just unlock the downloaded SweepX-LoftX-V2.2-bc14.2.06-1.dll and try again
Regards
UnblockDLL.jpg0 -
Hi Konstantin,
thanks!!! It works.
Win 8 ignore my security chanches in the dll file (now i put it in a new Folder and give the Folder full Access then it runs)
Best Regards!
Hannes
0 -
Hello Konstantin,
I have been reading a lot about your wonderful SweepX and LoftX routines and decided to give it a try recently. While the basic functions works and I understand it, I want to know if you have a latest documentation for all the options in the commands. That would be really wonderful.
At any point in future, if I want to download again the latest dll as well as documentation, what would be the URL?
Let me know.
Best Regards
Rakesh Rao
Smarter .dwg CAD0 -
Hi Konstantin,Excellent Feature. I was trying LoftX, it seems the transition at the radius of the path is direct. I require it to follow the path at the elbow/radius.Best Regards,Rajesh Celestine.
0 -
Hello Rakesh,
many thanks for your interest and nice words concerning the routines.
I am currrently updating the package and hope to be able to expose it in this thread within 2 weeks or so...
As for the command options of LoftX and SweepX and all other commands, you can get the explanations reading the online
documentation for the similar commands of the "BIG A"...
Sorry for this answer but for the time being i don't have any spare time for properly documenting in detail every option.
Some of the options of the SweepX command like "scale" or "Bank" don't work yet, due to internal problems of the ODA ACIS libraries.
The latest dll and documentation will allways be online in this thread and if not just give me a short notice.
I am hoping to finish some Lisp functions, that can be implemented only on the C# .NET side
like intersections between curves and Solids+Surfaces and possibly some Win-dialog interface Functions like Tree and Grid Controls...
Best Regards
Konstantin0 -
Hi Rajesh,
it seems that you have discovered a problem in the Core ACIS ODA libraries, the basic API library my plugin (the command LoftX and others) is based on.
Although the "Smooth" option is activated by default and the option "Path" are selected, the arc-segment of the Path-polyline is ignored!
So i'll place a support request.
In the meantime you can use a workaround to produce your lofted pipe :
Loft the three parts green, yellow and cyan solids separately using the LoftX command and then union them.
For the first and last solid (green and cyan) you can use the "path" option to create them(as you have propably already done).
For the yellow elbow-part interpolate a third profile circle (red one) at the midpoint of the elbow-arc with Radius = (R1+R2 / 2) where
R1 and R2 are the start and end cicles of the elbow respectively (in my case the middle-circle has R = 2.5+1.5 / 2= 2).
Then LOFTX the yellow elbow-solid without using the path option.
I hope this helps...
Best Regards
Konstantin
LoftedPipe-Elbow.jpg0 -
this plug-in is updated to a new version V2.3-bc14.2.12.
Two new Commands are available:
- PLANESURFACEX
The command creates surfaces (ACIS surface planar) from planar closed profiles like Lines, Polylines, 3Dpolylines, Regions, Circles, Ellipses, Arcs and 3Dfaces. In the case of 3Dfaces having 4 vertices
and being non-planar (consisting of 2 planar 3dfaces each one with 3 vertices), they are automatically converted in 2 planar surfaces. This functionality can be used to convert legacy meshes like Polygon- and Polyface meshes into ACIS Surfaces and Solids.
This was one of the reasons to create the command.
To do this conversion follow this sequence (see screenshot below from left to right) :
(1,2) Explode the Pface or Polygon mesh to 3Dfaces -->>
(3) Convert 3Dfaces to planar ACIS Surfaces with the PLANESURFACEX command -->>
(4) Union the surfaces with the UNIONX command to an ACIS surface -->>
(5) if needed SLICEX a solid by the produced surface to get a solid3D form. - SECTIONX
The command can section ACIS surfaces to produce contours (not in all cases due to internal API problems not yet resolved , see also screenshot below)
Two Options of the SWEEPX command can be used to overcome the lack of the “Scale” option in the native SWEEP command and the non-functioning options of the SWEEPX command, Scale, BANk and STart-draft-distance .
…..Enter an Option [Alignment/Basepoint/Scale/Twist/BANk/Draft-angle/STart-draft-distance/ENd-draft-distance]:
You will have to manually calculate either the Draft-angle or the ENd-draft-distance based on the Length of the sweep path or the wished Scale Factor respectively.
Example using the ENd-draft-distance:
Sweep Profile a circle , Diameter = 1.0
Path Curve a Line, wished scale Factor 2.0
ENd-draft-distance = [ (scale factor x Diameter) – Diameter] / 2 = 0.5
Thanks to continual improvement of the underlying .NET API and Teigha + ACIS wrappers and libraries some new features were made available in the last few months :
- Lofted Solids and Surfaces can now be created using Points as Start and End Profiles.
- Bricscad crash problems by the INTERFEREX and UNIONX commands are now fixed.
- All created objects have the current active color
Regards
Konstantin
Contouring.jpgPolyfaceMesh.dwgSweepX-LoftX-V2.3-bc14.2.12.dll
LegacyMesh2 Solid.jpg0 - PLANESURFACEX
Konstantin, when I attempt to load SweepX-LoftX-V2.3-bc14.2.12.dll in Briscad (64) 14.2.12 the load fails as:
C:\Program Files\Bricsys\BricsCAD V14 en_US\bdm_module.tx module initialized
: NETLOAD
* Runtime Extension is already loaded.
Error Message: Could not load file or assembly 'file:///C:\Program Files\Bricsys\BricsCAD V14 en_US\SweepX-LoftX-V2.3-bc14.2.12.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
; [0]...BRXLOADMANAGEDDLL <<--<br>;
failed to load module C:\Program Files\Bricsys\BricsCAD V14 en_US\SweepX-LoftX-V2.3-bc14.2.12.dll
This is under Windows 7 64 Pro. Loading the earlier version SweepX-LoftX-V2.2-bc14.2.06-1.dll works okay.0 -
Hi,
See if post #45 in this thread helps resolve the loading issue
Dan
0
