Xref fade control
We would like o use the xref with fading but the variable XFADECTL wont work....
Any advice to fade the xref ?
Thanks
PS: Bricscad is available on mac ? -
XDWGFADECTL is the proprty to control fading of Xrefs. Unfortunately this feature is not yet available in Bricscad.
You could do a basic simulation of this by using layer states. Once you have xrefed in all the files you want, and have set there layer settins how you want save the layer state to say "Normal". Then change the layer colours to a grey scale or dull colour to fade. Save this layer state as "FADE". Not as dynamic, and a bit rough.
Regards,
Jason Bourhill
CAD Concepts
http://www.cadconcepts.co.nz -
this XDWGFADECTL needs to be added. Should be a simple add. I think CAD has had it since 2006.
They need to add locked layer fading, too.
Howdy, Stranger!
