"3D solids conversion to unfoldable sheet metal parts" ? Need info
I had run across this line in documentation sometime the past few weeks.
Anyone know where i can find it or any info?
The command is called _smConvert. It can be found in the Sheet Metal toolbar and menu. The 3d solid must be have thin walls that, I think, must match the sheet metal thickness set in the Mechanical Browser.
OK good things to consider.
Cant wait to try it.
Thanks much.
Howdy, Stranger!
