How to make a per-document variable with .net?
On the autocad side, a variable will be global to a document, unless declared as static. Static cars are global to all docs.
On the bricscad side, it seems a static variable is still global to all docs, but a non-static var is not global to anything.
Use this test code to see (from Kean's blog...):
public class SecondClass {
//if this var is static, it affects all sessions
private int counter1 = 0;
private static int counter2 = 0;
[CommandMethod("loc")]
public void local() {
Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("\nCounter value is: " + counter1++);
[CommandMethod("loc2")]
public void local2() {
ed.WriteMessage("\nCounter value is: " + counter2++);
When I run the loc command in bcad, its 0 every time.
In acad, it counts up from 0, and starts over in each doc as its nont static.
How would I make a vra global to each doc, not all docs?
meant "Static vars are global to all docs."...0
[code]
namespace BrxMgdTestCs
public class PersistedClass
public int val;public PersistedClass()
val = 0;
public class Commands : IExtensionApplication
public void Initialize()
}public void Terminate()
}[CommandMethod("doit")]
public static void doit()
Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
PersistedClass pclass = new PersistedClass();
pclass.val = doc.Editor.GetInteger("Enter a number").Value;
doc.UserData.Add(typeof(PersistedClass), pclass);}
[CommandMethod("getit")]
public static void getit()
if(doc.UserData.ContainsKey(typeof(PersistedClass)))
PersistedClass pclass = doc.UserData[typeof(PersistedClass)] as PersistedClass;
doc.Editor.WriteMessage(pclass.val.ToString());
[/code]0 -
val = 0;
}[CommandMethod("getit")]
}0 -
Of course you can use any type for the key , object. It could just as well be:
doc.UserData.Add(String, int);
The plus side of using Document.UserData, is that it easy to get the values for any document from any command and or classUserData is a HashTable
Cheers
0 -
The ubiquitous DOIT command strikes again
Best wishes for a safe holiday guys.Regards,0 -
Best wishes for a safe holiday guys.Regards,Lol, I wonder how many doit functions I have out there : )
Best wishes to you and family as well : )
0 -
more fun
public int val;
val = 0;
public void DoSomething()
doc.Editor.WriteMessage(val.ToString());
PersistedClass pclass = null;
if (doc.UserData.ContainsKey(typeof(PersistedClass)))
else
if (pclass != null)
pclass.val++;
pclass.DoSomething();
}0 -
so doc.userdata is the only way? Its funny because is the acad behavior of non-static vars correct, or bcad?
It does not matter, I have to choose a method that works for both as I want one codeset with as few #if forks as possible.
Thanks for the responses - with example code no less, much appreciarted.
0
