How to make a per-document variable with .net?
On the autocad side, a variable will be global to a document, unless declared as static. Static cars are global to all docs.
On the bricscad side, it seems a static variable is still global to all docs, but a non-static var is not global to anything.
Use this test code to see (from Kean's blog...):
public class SecondClass {
//if this var is static, it affects all sessions
private int counter1 = 0;
private static int counter2 = 0;
[CommandMethod("loc")]
public void local() {
Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("\nCounter value is: " + counter1++);
[CommandMethod("loc2")]
public void local2() {
ed.WriteMessage("\nCounter value is: " + counter2++);
When I run the loc command in bcad, its 0 every time.
In acad, it counts up from 0, and starts over in each doc as its nont static.
How would I make a vra global to each doc, not all docs?
  • meant "Static vars are global to all docs."...
  • [code]
    namespace BrxMgdTestCs
        public class PersistedClass
            public int val;
            public PersistedClass()
                val = 0;
        public class Commands : IExtensionApplication
            public void Initialize()
            public void Terminate()
            [CommandMethod("doit")]
            public static void doit()
                Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
                PersistedClass pclass = new PersistedClass();
                pclass.val = doc.Editor.GetInteger("Enter a number").Value;
                doc.UserData.Add(typeof(PersistedClass), pclass);
            [CommandMethod("getit")]
            public static void getit()
                if(doc.UserData.ContainsKey(typeof(PersistedClass)))
                    PersistedClass pclass = doc.UserData[typeof(PersistedClass)] as PersistedClass;
                    doc.Editor.WriteMessage(pclass.val.ToString());
     [/code]
  • namespace BrxMgdTestCs
            public int val;
                val = 0;
  • Of course you can use any type for the key , object.  It could just as well be:
    doc.UserData.Add(String, int);
    The plus side of using Document.UserData, is that it easy to get the values for any document  from any command and or class
    UserData is a HashTable
    Cheers
    The ubiquitous DOIT command strikes again :)
    Best wishes for a safe holiday guys.
    Regards,
    Regards,
    Lol, I wonder how many doit functions I have out there : )
    Best wishes to you and family as well : )
  • more fun
            public int val;
                val = 0;
            public void DoSomething()
                doc.Editor.WriteMessage(val.ToString());
                PersistedClass pclass = null;
                if (doc.UserData.ContainsKey(typeof(PersistedClass)))
                else
                if (pclass != null)
                    pclass.val++;
                    pclass.DoSomething();
  • so doc.userdata is the only way? Its funny because is the acad behavior of non-static vars correct, or bcad?
    It does not matter, I have to choose a method that works for both as I want one codeset with as few #if forks as possible.
    Thanks for the responses - with example code no less, much appreciarted.
