Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
XREF appears vague.
 Hello
When I insert an XREF  into  a drawing the xref appears somewhat vague.  The xref is not as clear (distinct) as when seen as an independent xref drawing before
insertion.
This is fairly annoying since the xref does not give the contrast and clarity that is easy to work with.   I do not want to change the color or layer of the
xref to make it easier to read since I  have previously set layers and colors of xref for correct plotting.
Is there a simple switch that will allow the xref to be viewed after inserted with more clarity?
Thanks  H. Hampton.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
