Block
Yesterday I started working on a large architectural lighting layout drawing received from an architect.
The entire ceiling is a 2' x 4' grid, and the lighting fixtures are 2' x 4' layins.
But as I received the drawing the grid and lighting fixtures were on the same layer!!!!
Being new to BricsCad I thought this will be easy. Just edit the 2' x 4' block lighting fixrture (called fluor) and
everything will be separate layers as I needed. But I could edit the block and change everything but layer.
I tried attredef command and still could not separate the layers.
So I created a new layer and used the (move to current layer command) and transferred the light fixture blocks
one by one to the new layer ???!!! This was a tedious process. There must be a better way. Please assist.
Thanks H. Hampton.
0
You can use QuickSelect to select entities that share the same property, e.g. all blocks of the same name.See the BricsCAD Help under User Guide / Modifying Entities / Selecting Entities / Using Quick Select.0
Thanks.0
