Default
 When I enter the commands:
E    and then enter,            [erase command]
There is a pop up window for the options for erase such as window, etc.
How can I make window   (W)  the default for erase or other commands
without having to make a selection from the pop up window or maybe have to enter   [W and enter]  ?
It would be nice if it were similar to Autocad Lt that either  entity or window   [either or] were the default.
Thanks  H. Hampton.
  • You shouldn't have to pick an option for the erase command.
    Window and Crossing selection should be available automatically for any command, and for pre-selection without a command active.
    Do you have PICKAUTO turned off? That would cause the problem, but it would affect all selection, not just for Erase.
  •  Probably you just want to turn off the prompt menu. Just type PROMPTMENU and set to 0.
  •  Do the following to modify the ERASE tool (not the command):
    - Choose CUSTOMIZE in the TOOLS menu.
    - Select the ERASE tool in the EDIT toolbox in the AVAILABLE TOOLS list.
    - In the command field add ;w;
    the command field now reads: ^c^c_erase;w;
    Click the OK button to confirm the changes.
    The ERASE toolbutton and the ERASE menu item will now prompt to draw a selection window.
    If you want to use a shortcut, you must define one in the KEYBOARD section of the CUSTOMIZE window.
  •  Thanks to all for your replies.
