Default
When I enter the commands:
E and then enter, [erase command]
There is a pop up window for the options for erase such as window, etc.
How can I make window (W) the default for erase or other commands
without having to make a selection from the pop up window or maybe have to enter [W and enter] ?
It would be nice if it were similar to Autocad Lt that either entity or window [either or] were the default.
Thanks H. Hampton.
0
You shouldn't have to pick an option for the erase command.
Window and Crossing selection should be available automatically for any command, and for pre-selection without a command active.
Do you have PICKAUTO turned off? That would cause the problem, but it would affect all selection, not just for Erase.0 -
Probably you just want to turn off the prompt menu. Just type PROMPTMENU and set to 0.0
Do the following to modify the ERASE tool (not the command):- Choose CUSTOMIZE in the TOOLS menu.- Select the ERASE tool in the EDIT toolbox in the AVAILABLE TOOLS list.- In the command field add ;w;the command field now reads: ^c^c_erase;w;Click the OK button to confirm the changes.The ERASE toolbutton and the ERASE menu item will now prompt to draw a selection window.If you want to use a shortcut, you must define one in the KEYBOARD section of the CUSTOMIZE window.0
Thanks to all for your replies.0
