turn of Window for selection
I did it before but cannot figure it out again , how do I turn off this window ?
Sorry title should be OFF .Also for default dimension styles , how do I set them up from drawing to drawing , I looked in the help file but I am not getting it for some reason
1.
PROMPTMENU.
2.
Create a template (and keep it clean and up to date...). Make sure that all DIM settings are saved to a dimstyle.
You can import a dim style via the Drawing Explorer. -
Try the settings for the SHORTCUTMENU variable, if I'm understanding what you're looking for.
For dimension styles, there may be other/better ways but I set them up in a default template, one for imperial and one for metric, along with the other personalizations. -
Thanks Guys that did it ! you ROCK
Can someone explain workset to me please ( there is no explanation anywhere I can find ) does it act like XREF in ACAD ? do you add 3d parts into a workset or ??
Can someone explain workset to me please ( there is no explanation anywhere I can find ) does it act like XREF in ACAD ? do you add 3d parts into a workset or ??I got it , found a video thanks
Now you raised the question, can you tell us the answer you found? (link to the video)
Now you raised the question, can you tell us the answer you found? (link to the video)I searched it again and cannot find the link sorry ??? I will search more
Howdy, Stranger!
