STEP opening
hi,
I cannot open a STEP file (which I often get from suppliers...). I found out that this is not possible with Bricscad.
But, how to open a step file and make dwg files of them (e.g. top view)?
Best,
Bas
I believe you need the platinum edition and the communicator add-on. Do you have these?
https://www.bricsys.com/en_GB/communicator/index.jsp
If not can your supplier provide a (ACAD) DWG rather than a step? There are also pay per-use online converters if buying the communicator add-on is not an option.
Howdy, Stranger!
