Convert to arc
In Autocad when I PE (Poly Edit) and right click on a poly line I get a command "Convert to Arc"
I can't see this command in Bricsys How can I add this to the menus that appear when I right click on a poly line ??
Regards Julian B
The Explode command converts a polyline to lines and arcs. You can add the Explode command to the Edit context menu.
Choose Customize in the Tools menu and in on Menu tab page expand the Edit command group in the Context Menus node. Now you can drag the Explode comman from the Available Commands list to the Edit context menu.0 -
Julian, do you mean the pop up? In that case you should do
PEDIT, select the poly-line, chooseEdit vertices andenter(is Next) enough times until the cross is at the start of the segment you want to become an arc segment. Next you chooseAfor Angle. Enter for example90.xfor eXit and anenterfor the next Exit.Now you can edit the nodes by selecting the poly-line.
The Angle entered... If you enter
0, an arc segment becomes a line segment.Delete nodes/vertices: option
Straighten.Add nodes: option
Insert0 -
I misunderstood your question. The easiest way to change the 'Bulge Factor' of a polyline segment is in the Properties Bar:
- Select the polyline
- In the Properties Bar: click the Vertex field
- Use the arrow buttons to select the start vertex of the segment you want to modify
- Edit the Bulge field.
0
