Missing Tools
Hello Shape team,
In my opinion, some tools are missing for a common use of Shape.
for example :
  • Dimensions
  • stretch
  • polar array
  • array path
Are you planning to integrate them in a future release?
Best.
  • Ahm, why Dimensions ?
    (If it is about those 2D annotation tools)
    As it is a 3D sketch modeling App.
    In Scale and Units of course.
    So do you think about presentation needs or to control
    modeling scale ?
    I would like to be able to all time read out length, width, height and
    XY and base Z in World + Local Coordinates.
    Distance Tool is existing but the rest should be available in a
    Property Pane, Rollover Tips and all time cursor snapping read outs
    if needed. Or a temporary 3D Dimensions Frame like found in Polygon
    Modelers, editable like DYNDIMs at best.
    I miss that in Bricscad too though.
    modeling scale ?
    I think that Dimensions are a good way to control the modeling and to realize a minimal documentation of the drawing like in SKETCHUP.
    Best
  • Xrefs are integrated in Shape.
    You can load a DWG with an XREF but you can't deal with it.
    That would be easier to deal with XREFs Inside Shape.
    What about the next realease, Bricsys Team ?
  • Hi ShapeTeam,
    Line types are integrated in SHAPE.
    But we miss a way to access line type inside SHAPE and access to objects properties in this first release.
    Best.
  • Hi ShapeTeam,
    It would be fine if we could easily , as in SKETCHUP, use the distance tool to add guide lines made of infinite lines (with predetermined préférences for type of line and colour).
    Best.
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
