Missing Tools
Hello Shape team,
In my opinion, some tools are missing for a common use of Shape.
for example :
  • Dimensions
  • stretch
  • polar array
  • array path
Are you planning to integrate them in a future release?
Best.
  • Ahm, why Dimensions ?
    (If it is about those 2D annotation tools)
    As it is a 3D sketch modeling App.
    In Scale and Units of course.
    So do you think about presentation needs or to control
    modeling scale ?
    I would like to be able to all time read out length, width, height and
    XY and base Z in World + Local Coordinates.
    Distance Tool is existing but the rest should be available in a
    Property Pane, Rollover Tips and all time cursor snapping read outs
    if needed. Or a temporary 3D Dimensions Frame like found in Polygon
    Modelers, editable like DYNDIMs at best.
    I miss that in Bricscad too though.
    modeling scale ?
    I think that Dimensions are a good way to control the modeling and to realize a minimal documentation of the drawing like in SKETCHUP.
    Best
  • Ok, I agree.
  • Xrefs are integrated in Shape.
    You can load a DWG with an XREF but you can't deal with it.
    That would be easier to deal with XREFs Inside Shape.
    What about the next realease, Bricsys Team ?
  • Hi ShapeTeam,
    Line types are integrated in SHAPE.
    But we miss a way to access line type inside SHAPE and access to objects properties in this first release.
    Best.
  • Hi ShapeTeam,
    It would be fine if we could easily , as in SKETCHUP, use the distance tool to add guide lines made of infinite lines (with predetermined préférences for type of line and colour).
    Best.
