Toolbar trails when moving them V18
Had no idea where to put this one. When I move/relocate toolbars it creates "trails" that disappear once done moving. Not a game breaker but kinda hard to pinpoint when placing the toolbars, did not do this in V16 with same hardware.
  • This is a bug in Windows 10 Fall creators update (also known as Windows 10 build 1709). It affects all applications using a drag rectangle when dragging toolbars and control bars (including old versions of BricsCAD, all versions of AutoCAD, and many others).
    Please go to the following feedback in Windows 10 Feedback Hub and upvote the bug:
    https://aka.ms/D1qxt7
    Windows 10 1709 breaks the MFC CControlBar drag (causing a mess on screen)
    Hopefully upvotes on the bug report will help convince Microsoft to get it fixed quickly.
  • Thanks Owen!
