BricsCAD Plugins in an other CAD Systeme
Dear community
We have CAD plugins on Bricscad. these plugins are CAD independent (programming language is c ++ based on framework). We also like to offer these plugins on other CAD systemes like Intellicad, DraftSight.
Does anyone have experience with it? Interesst todo this job for our company?
  • You mean you wrote them but do not know how to make work on the other acad clones?
    I do progs in c# that run on both acad and bcad with same codeset, and it typically just switching out the references in the VS project, as well as using alias for objects like this:
    //AutoCad Usings
    if ACAD
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.ApplicationServices;
    using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
    using AcDoc = Autodesk.AutoCAD.ApplicationServices.Document;
    using Autodesk.AutoCAD.EditorInput;
    using AcEd = Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.DatabaseServices;
    using AcDb = Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Geometry;
    using AcGe = Autodesk.AutoCAD.Geometry;
    using AcCo = Autodesk.AutoCAD.Colors;
    using Autodesk.AutoCAD.Windows;
    using Autodesk.AutoCAD.GraphicsInterface;
    using AcIn = Autodesk.AutoCAD.Internal;
    endif
    if BCAD
    using Teigha.DatabaseServices;
    using AcDb = Teigha.DatabaseServices;
    using Bricscad.EditorInput;
    using AcEd = Bricscad.EditorInput;
    using Teigha.Geometry;
    using AcGe = Teigha.Geometry;
    using AcCo = Teigha.Colors;
    using Teigha.Runtime;
    using Teigha.GraphicsInterface;
    using Bricscad.Runtime;
    using Bricscad.ApplicationServices;
    using AcAp = Bricscad.ApplicationServices.Application;
    using AcDoc = Bricscad.ApplicationServices.Document;
    using Bricscad.Windows;
    endif
    This is basic for people using VS and .net, not sure if same for C++ but hit the autodesk dg's to catch experts there.
  • wow, ignore the huge text there, it was supposed to be like:
    #if ACAD
