Good Shape ...
I'm trying Shape... I had soon the impression that could be really a good and better alternative to Sketchup.
I'm really appreciated the tool to easily connect, trim and extend forms, wall, etc...
I hope for some new features:
- saving scene/view to export in dwg or jpg;
- a better rendering shadows;
- dimensions;
- more stability;
here my test of my renovation project
Nice !
Where did you set your nice red Section Face Color,
or is this just the 2D Overlay ?0 -
Hi Michael... i'm just colorized the face on top of the wall.
The 2d is a reference draw made with another sw that I can update and then modify the 3d in BC shape0 -
Nice !
Didn't expect that you could apply different colors (materials too ?)
to a single Solid.0 -
IF U EXPLODE SOLID U CAN COLOUR EVERY FACE
0 -
No need to explode, just select the face
0 -
yes, but for now, if you apply a material, you lose this feature. It doesnt apply material o a single face...
but I hope in next upgrade0 -
Indeed, only color per Face in Shape.
But Material per Face works in Bricscad.
So in Shape more a problem of the limited UI without
Property Panel or configurable Roll Over Tips.0 -
if u need color any face just select face and change color from QUAD CURSOR menu ( press f12 if not visibl When you pass the cursor over an entity ),, if u need apply different material to each faces of one solid explode solid working with me
0
