Good Shape ...
I'm trying Shape... I had soon the impression that could be really a good and better alternative to Sketchup.
I'm really appreciated the tool to easily connect, trim and extend forms, wall, etc...
I hope for some new features:
  • saving scene/view to export in dwg or jpg;
  • a better rendering shadows;
  • dimensions;
  • more stability;
    here my test of my renovation project
  • Nice !
    Where did you set your nice red Section Face Color,
    or is this just the 2D Overlay ?
  • Hi Michael... i'm just colorized the face on top of the wall.
    The 2d is a reference draw made with another sw that I can update and then modify the 3d in BC shape
  • Nice !
    Didn't expect that you could apply different colors (materials too ?)
    to a single Solid.
  • IF U EXPLODE SOLID U CAN COLOUR EVERY FACE
  • No need to explode, just select the face
  • yes, but for now, if you apply a material, you lose this feature. It doesnt apply material o a single face...
    but I hope in next upgrade
  • Indeed, only color per Face in Shape.
    But Material per Face works in Bricscad.
    So in Shape more a problem of the limited UI without
    Property Panel or configurable Roll Over Tips.
  • if u need color any face just select face and change color from QUAD CURSOR menu ( press f12 if not visibl When you pass the cursor over an entity ),, if u need apply different material to each faces of one solid explode solid working with me
