Select Object Drop-Down Arrow for changing LAYER not there :
PLEASED to see the add of Zoom-Object !
Question: When I select an object, the ability to change its Material drop-down arrow appears AS EXPECTED. Why am I NOT able to find a similar Drop-Down Arrow for changing other parameters such as LAYER Assignment ? In my LICENSED V-12 - I have FULL control over any property I want to change EXACTLY as in ACAD and a number of OTHER CAD Programs B-CAD competes with .
  • The arrow shows up here when selecting a 3D object and then material etc. in the properties palette or the entity properties toolbar.
    Did you try to reset your workspace to see if that solves the issue?
  • What drop down arrow? Am I missing out on something ?
