Unwanted white rectangle on gray background
Probably a dumb question.
I have a white rectangle with dashed line inset in paper space. How do I get rid of this?
I just installed version 19 on a new computer. Not sure why rectangle was absent on old computer.
Looks like the Paper Size with Printing Border.
Your Viewports are exceeding that chosen Paper. -
Michael is correct. You can disable it by changing the DISPPAPERBKG and DISPPAPERMARGINS settings. For some strange reason this is only possible via the _Settings command.
Yes! This works. Thank you Michael and Roy.
- True, you need to modify it in the settings dialog. If I type the variable name (only tried first one), I get this:
- DISPPAPERBKG
Undocumented variable. Cannot be modified on the commandline.
But it really is documented a bit. See bottom left of the Settings Dialog
Dummy text that gets covered by image
Dummy text that gets covered by imageI rarely print a drawing, so I don't see the need for a paper size anyway. Usually I export to pdf.
Howdy, Stranger!
