Block manager
thanks a lot Daniel Marcotte sir.0
Ive ran into some problems with ExtTools:At installation i get:Install ErrorThis module requires Bricscad version 11.2.0 or newer to runThe version io run is Bricscad Pro 11.4.6When i try to load it thru appload i get this:Loading C:\Program\CadExt\ExtTools\ExtTools.arx: (arxload "C:/Program/CadExt/ExtTools/ExtTools.arx")Error loading "C:\Program\CadExt\ExtTools\ExtTools.arx": .Error loading "C:\Program\CadExt\ExtTools\ExtTools.arx": .* (arxload) : can not LOAD filenil0
Ooops, my error for not changing that error message. You actually need V12 . sorry about that. Post #43 has an attachment for v11 that you should be able to fire up, caveat its missing a feature or two.
Sorry about that : |
Dan
0 -
Dan
Thank you, That one went right in without any problems. ;D0 -
Does anyone still have this tool? Original poster's website is no longer valid.
0 -
I think Daniel is still active in the BricsCAD arena, maybe he will respond in a couple days. We have put together a freeware alternative (see separate post). Our tool is lisp based and should work on Classic and maybe even on non windows platforms.
0 -
