How to create a custom panel?
Hi,
I would like to create a custom panel, i.e. a little window that can be docked to the left or right side and show a treeview list of items, like the structure panel. I'll be finde to fill the panel, however I need to the starting point. For example, what is the container object to put the control into? If anyone has a little example for this, I would be very grateful!
Thanks
  • Which API will you be using?
    I will be using the .Net Api, developing in C#/Visual Studio. Sorry, I forgot to mention that.
  • Hi,
    You can use a PaletteSet with a UserControl (palette tab) containing your TreeView.
    Here's a simple example, The CustomPaletteSet class inherits from PaletteSet.
    It contains an instance of TreeViewTab class, the custom class derived from UserControl which contains your TreeView control.
    using System;
    using Bricscad.Windows;
    namespace BricscadPaletteSample
        /// <summary>
        /// Describes a custom palette set
        /// </summary>
        public class CustomPaletteSet : PaletteSet
            /// <summary>
            /// Creates a new instance of CustomPalette
            /// SHOW_PALETTE is the name of the command used to set the palette visible
            /// </summary>
            public CustomPaletteSet() : base("SHOW_PALETTE", new Guid("{0CF42D05-06C0-4D77-9648-04E293538098}"))
                Name = "Palette";
                Style = PaletteSetStyles.ShowAutoHideButton |
                        PaletteSetStyles.ShowCloseButton |
                        PaletteSetStyles.ShowPropertiesMenu;
                MinimumSize = new System.Drawing.Size(250, 150);
                Dock = DockSides.Left;
                // add a palette tab (derived from System.Windows.Forms.UserControl) to the palette set
                Add("Tree View", new TreeViewTab());
    The Commands class where the command to set the palette visible is defined
    using Teigha.Runtime;
        public class Commands
            static PaletteSet palette;
            [CommandMethod("SHOW_PALETTE")]
            public static void ShowPalette()
                if (palette == null)
                    palette = new CustomPaletteSet();
                palette.Visible = true;
