How to create a custom panel?
Hi,
I would like to create a custom panel, i.e. a little window that can be docked to the left or right side and show a treeview list of items, like the structure panel. I'll be finde to fill the panel, however I need to the starting point. For example, what is the container object to put the control into? If anyone has a little example for this, I would be very grateful!
Thanks
Which API will you be using?
Hi,
You can use a PaletteSet with a UserControl (palette tab) containing your TreeView.
Here's a simple example, The CustomPaletteSet class inherits from PaletteSet.
It contains an instance of TreeViewTab class, the custom class derived from UserControl which contains your TreeView control.using System; using Bricscad.Windows; namespace BricscadPaletteSample { /// <summary> /// Describes a custom palette set /// </summary> public class CustomPaletteSet : PaletteSet { /// <summary> /// Creates a new instance of CustomPalette /// SHOW_PALETTE is the name of the command used to set the palette visible /// </summary> public CustomPaletteSet() : base("SHOW_PALETTE", new Guid("{0CF42D05-06C0-4D77-9648-04E293538098}")) { Name = "Palette"; Style = PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowCloseButton | PaletteSetStyles.ShowPropertiesMenu; MinimumSize = new System.Drawing.Size(250, 150); Dock = DockSides.Left; // add a palette tab (derived from System.Windows.Forms.UserControl) to the palette set Add("Tree View", new TreeViewTab()); } } }
The Commands class where the command to set the palette visible is defined
using Bricscad.Windows; using Teigha.Runtime; namespace BricscadPaletteSample { public class Commands { static PaletteSet palette; [CommandMethod("SHOW_PALETTE")] public static void ShowPalette() { if (palette == null) palette = new CustomPaletteSet(); palette.Visible = true; } } }
Howdy, Stranger!
