plot outside of a poligonal viewport
Hello.
I have a big problem with Bricscad..
when i create a Poligonal viewport in the paperspace (not rectangular viewport) with a few vertex.. like 7.... when plot (any plotter, even print as PDF option)... lines, text and other model entities plot outside the poligonal viewport..
i tried freezing and on/off the viewport layer.. using VP layer or Defpoint layer for the viewport... nothing..
i am uploading a file for example
in magenta color is the poligonal viewport
any solution?
What a messy drawing! Your viewport is outside the page boundaries.
i don't use the page view in the viewport... i don't like that. I disabled it in settings..
but this is not the point @CADMebel ...
the drawing is an example of the problem.
can you reproduce the problem?
I can confirm the issue. After a bit of paying around I find that (some of?) the texts in modelspace are causing the problem. But I can't identify what is wrong with them. Copying all texts in-place (tip: use Quick Select), and then deleting the originals fixes things.
You should send in a Support request.
Howdy, Stranger!
