Load Selection in console ERROR
(setq lst '(1 74678.6 53741.6 0.0))
(setq result
(vl-string-subst "" ")"
(vl-string-subst "" "(" (vl-prin1-to-string lst))
Loading this in the Console causes this error
(PRINC)
; error : malformed list on input at [read]
The statement inside the result assignment CAN be loaded sucessfully.
https://gyazo.com/4879dd77b1a94e8f4bbef45489337197
added:
What is the address for the development team so this can be sent direct ( next time )
Dear Kerry,
many thanks for reporting ... I will check this scenario to see what goes wrong.
"What is the address for the development team so this can be sent direct ( next time )"
normally, just send us a support request, it will be handled by the support and development team then.Where necessary, small dwg file(s) and code snippets can be attached there as well.
many greetings !0 -
Thanks Torsten
Version 19.2.07 (x64) revision 61634 en_us
Win 100 -
Dear Kerry,
thanks for providing the version
I would have asked for this anyway ...
just checking the problem ...
more to come & many greetings !0 -
Dear Kerry,
I found and fixed that problem (for V20) ...
you might bypass the problem by using "Load Selection in BricsCAD", the result is also shown in Console window/panel.thanks & greetings !
0 -
Thanks Torsten.
I appreciate the effort and attention to detail.As an aside, a cleaner solution to the programming purpose was suggested by Roy :
(vl-string-trim "()" (vl-prin1-to-string lst))
Regards,
0 -
Ah, yes ... as we all know, Roy is a real wizard
many greetings !0
