Trouble posting bug reports
I'm not able to post bug reports. The box to the right of the language requires a valid value in order to send a report, but the drop-down has no entries and there is no tag indicating what goes in the box.
Is anyone else having this problem? Any suggestions on how to work around this?
  • Yes, I've had other users report the same issue. I've sent a request through to Bricsys to get it fixed via a different channel. Hopefully will be back running soon. The problem seems to be just for users of the English language version.
    Regards,
    Jason Bourhill
    BricsCAD V19 Ultimate
    Quickly create HELP links on your forum posts
    CAD Concepts
  • Jason,
    Thanks. I was able to post by selecting Spanish as the language, although the version I downloaded yesterday was not available in the drop-down.
  • In the mean time, you should be able to file support tickets again, without work-arounds. Let know if you still experience issues.
