It looks like you're new here. If you want to get involved, click one of these buttons!
I needed several Components / Standard Part / Holes and after I created the first one decided to copy the rest since the 'Hole' edit sequence doesn't default to remembering what hole I used last.
The first hole (bottom hole) looks like a hole as I can see through it. The copied hole (top) is opaque. Is this a bug?
Currently COPY of a hole only works correctly if done on the same solid body. In you case it looks like you're copying to another solid.
Workaround in this case is to force an update. You can do this with BMUPDATE, when it asks you to select objects, pick the solid and the hole. For reference BMUNLINK does the opposite, breaking the link between the hole and the target solid.
Regards,
Jason Bourhill
BricsCAD V19 Ultimate
Quickly create HELP links on your forum posts
CAD Concepts
Thank You.
I'll experiment with those commands.
