Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Unbounded Hatch
in the other cad
_HATCH w
allows to draw hatch interactively
Can this BCAD or does anyone know of lisp or such.
Answers
  • edited October 2019
    Do you mean like this?
    ; Create a hatch by picking its corner points.
    (defun c:h2 ( / b1)
    (command "pline")
    (while (> (getvar "cmdactive") 0) (command pause))
    (setq b1 (entlast))
    (command "pedit" b1 "close" "")
    (command "-hatch" "s" b1 "" "")
    (command "erase" b1 "")
    ; (command "draworder" "L" "" "B")
    ; (command "selgrips" "L" "") (setq ss1 (ssget))
    ;  (if ss1 (setq ent1 (entsel "Select Object to clone from...")))
    ;  (if ent1 (command "Matchprop" ent1 ss1 ""))
    ; If you delete the semicolon before the Draworder command,
    ;   it will move the new hatch entity to the back.
    ; If you delete the semicolons before the next 3 lines,
    ;  it will prompt you for an object to copy properties from,
    ;  and then assign those properties to the new hatch.
    ; If you delete the semicolon before the final Selgrips command,
    ;   it will leave the new hatch selected and highlighted,
    ;   so you can choose its pattern from the Properties panel.
  • Anthony Apostolaros,
    Very cool lisp routine; now have an H2 & H3 (selgrips option) added to the toolbox. Thank you.
    Mike
  • Mike,
    I like it too. Thanks for the idea.
    My first impression was "why would anybody want that?" But it was easy to write, so I tried it. And then I saw that it would be very useful. So I put it in my automatically-loaded lisps file. Now I don't have to have polylines ready to select for select-polyline hatching, or layers that I can turn off temporarily for pick-points-inside hatching.
    I only use the one with Selgrips, though. I work with PickAdd off. All my entity-creating commands end with the newly created entities selected. All my editing commands end with the selection set that was moved, rotated, etc. still selected.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
