Profile Axis lines
There is a command, 'DISPLAYAXES' which turns on the axis lines for BIM profiles.
Is there a command that can turns off the profile but leaves on the axis lines?
I have found that the profiles can be manipulated using the grips on the profile axis line which is a good feature however I would like to check the model and just having the axis lines displayed and not the profile outlines would be more convenient.
TIA
I asked a similar question about exporting the axes lines in a did dwg other format. Also I would like the the second axis defining the plane of rotation orientation as well. - most structural analysis/fabrication programs will expose this and I find it essential for interoperability. You can use the grasshopper components to get the axes lien and expor/bake but you cannot get a rotation angle and /or reference axis for the section orientation. This should be easy for bricsys to expose and invaluable.
If you want the axes lines then you need to use grasshopper and bake them to a excel/dwg file or bake them back to bricsys
Howdy, Stranger!
