(V20)MULTILEADER does not display the character size correctly.
(settings) When drawing with both the text size and arrow size set at 2 mm and the overall scale set at 5, only the text is drawn at 2 x 5 x 5 = 50 mm. If you copy it and edit only the text, only the text is multiplied by 5 (50 x 5 = 250 mm). MULTILEADER is also known to decompose when opened with AUTOCAD.
  • Put in a bug report on the support page. I did because V20 has misaligned my multileader. So I think the new v20 multileader system is faulty.
  • Yes, I did.
    I received the following reply.
    Our developers are aware of this issue, I will return with future notice when the problem is fixed.
    Best Regards,
    Thank you.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
