Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Missing grdraw during slicing
edited January 2 in 3D Modeling
I miss the (ortho) line indication for precision slicing in graphic mode (keyless entry).
Check this video what i mean, extrude has it. And ThatOtherCAD has one too for slicing. Need to have
Some code like beneath. Lee Mac's grdraw function.
(while (not p1)
(setq p1 (getpoint "\nPick or specify start point : "))
(while (not p2)
(setq p2 (getpoint p1 "\nPick or specify end point : "))
(grdraw p1 p2 6 1)
  • edited January 2
    As a workaround try using temporary tracking: After the first point enter 'tk' and then '@'.
  • edited January 3
    I figures it out. Some more possibilities. It needs an extra [Enter] to trigger the ortho lines in 3points option. Little different than i used to do in Autocad. Thanks!
    (Defun c:sli () (command "slice" (ssget) "" "3points"))
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
