It looks like you're new here. If you want to get involved, click one of these buttons!
I ran into this today on V20, all builds.
Using the lisp function GRDRAW is about 4x slower than in V19/V18, and it does not draw correctly.
It seems to blank out other items from GRDRAW, ash shown in the test function below.
The code below runs instantly in autocad, 2 seconds in V18/V19, and 9 seconds in V20.
I use GRDRAW extensively in general utility and also civil design tools, so its a deal killer for us for V20.
I did a support request on this so I'm sure the bricsys team will get back to me soon.
I am transitioning my civil tools to transient entities using .net, and that works well for temp items shown on screen during commands.
I still have several tools though, that leave items shown on screen after a command. The test code below is part of a tool that reports drawing health on file open.
I can't have 9 seconds delays on startup so may have to rethink some things if this is a deep issue.
Try this code (I do all caps for lisp, sorry...)
(DEFUN C:CTTESTGR ( / ANG CENLT LL SCREENWIDTH SHIFT UL VCTR VT WIDTH XINC)
(SETQ SCREENWIDTH (* (/ (CAR (GETVAR "SCREENSIZE"))(CADR (GETVAR "SCREENSIZE")))(GETVAR "VIEWSIZE"))
VT (GETVAR "VIEWTWIST")
(WHILE (< VT 0.0)
(SETQ VT (+ VT (* 2.0 PI)))
(WHILE (> VT (* 2.0 PI))
(SETQ VT (- VT (* 2.0 PI)))
(SETQ WIDTH (* 0.8 SCREENWIDTH)
VCTR (TRANS (GETVAR "VIEWCTR") 1 0)
CENLT (POLAR VCTR (- PI VT)(/ WIDTH 2.0)) ;20% TO LEFT
UL (POLAR CENLT (- (/ PI 2.0) VT)(/ (GETVAR "VIEWSIZE") 4.0)) ;25% TO TOP
LL (POLAR CENLT (- (/ PI -2.0) VT)(/ (GETVAR "VIEWSIZE") 4.0)) ;25% TO TOP
XINC (/ WIDTH 2000.0)
SHIFT 0.0
;LOOP AND DRAW 100 LINES VERTICALLY
(REPEAT 2000
(GRDRAW (TRANS (POLAR LL (- 0.0 VT) SHIFT) 0 1)
(TRANS (POLAR UL (- 0.0 VT) SHIFT) 0 1)
7
(SETQ SHIFT (+ XINC SHIFT))
Confirmed. Much faster if the TRANS functions are removed. In V20 I got a time for the repeat loop of 11157 milliseconds with TRANS and 1969 milliseconds with TRANS commented out. In V19 the times were 984 ms with and 563 ms without.
In the latest V20 build, this indeed has been fixed.
Thanks to the Bricsys team for attending to it! V20 is BACK!
