Stability under Linux: Quad
After vanilla install, several crashes occurred. First I changed savetime
to 5 (!) At some point apport showed up and I noticed a segmentation fault related to the Quad. So I turned that off, together with tooltips.
This was a few weeks ago and since then, everything is rock stable. Although I've lost apport information, it is probably saved in /var/crash, I thought it might be a good idea to share this information.
(System: AMD, Xubuntu 19.04, BricsCAD v19)
So you don't use the Quad? I like that feature, but I would give it up if it meant I wasn't crashing so much. I just need to figure out how to turn these things off.
Thanks for the hint,
So Bricscad is also running fine on XCFE ?
It does indeed.
I just spent the whole afternoon restarting my BricsCAD or waiting for it to come out of a hang quitting, rinse, repeat. I was very excited to have a few good hours this morning on my new linux work station. But now, sometimes my files only stay open for a few seconds. The 3D BIM model is more stable than my sheets. But, everything is having crashes and hangs in v19 (and v20 as I was excited to try it with the new release.) Is it possible to have such bad settings or file parameters that it becomes unworkable?
Audit is not finding issues.
I think turning off Quad helps, but that is such a key part of workflow for me it's hard. I turn off tool tips, but how do I make that a default setting?
(System: Intel, with AMD graphics, Pop_OS 19.10)
I have to add: Wiebe, you saved my goose today. I have worked since my last comment without crashing. Bricsys can work on a specific bug instead of a ranting crying me.
Glad it helped minimalix. In Stockholm I had a discussion about this with Torsten Moses and he pointed out the problem was a bit deeper rooted. I can't remember the details, maybe he can elaborate on it. However, it is a pity to understand it persists in v20 too. It needs attention from developers. I thought there was a support request about this, not 100% sure.
Hm, we have never been forced to disable the quad in order to make BricsCAD run well.
Maybe you should try some of these settings..
- Make sure you are using a compositor on your system. If you are on Gnome or Plasma, that should be taken care of by the DE by default.
- Make sure you are not using Wayland, but use Xorg.
- Depending on your hardware and your version of BricsCAD, try some of the following:
In v19 and earlier versions to avoid push-pull crashes; Edit '~/.bricscad/config' and set 'DRAGMODEINTERRUPT=0' and set ''CROSSHAIRDRAWMODE=0'.
In v20 it seems to be fine using the default values of 'DRAGMODEINTERRUPT=1' and 'CROSSHAIRDRAWMODE=3' in '~/.bricscad/config'.
In v19 and earlier versions we used 'GLSWAPMODE=2' or 'GLSWAPMODE=3' in '~/.bricscad/config' with the open source AMD drivers, depending on the GPU generation present on the system.
In v20 (when 'CROSSHAIRDRAWMODE=3') it seems like 'GLSWAPMODE=2' in '~/.bricscad/config' works well for all versions of the open source AMD driver.
At this point, I can confirm that v20 is stable in an out of the box installation environment, with and without compositor, with QUAD enabled, AMD community drivers.
CROSSHAIRDRAWMODE 3
seems okay, though I have not tried it with some 3D-constraints, causing cursor duplication during command input in v19.
Howdy, Stranger!
