Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
XREF Fade Control Tips Needed - Example Given
QUESTION 1
Which commands/settings control the XREF color and transparency?
QUESTION 2
Are there any XREF visibility control commands included in AutoCAD that are not included in BricsCAD?
MY ISSUE EXAMPLE
To adjust a single XREF attachment to show as Color 9 or light gray (or grey), I had to open the attached file and change the color of all entities to Color 9.
I understand there is a relation between Property Panel Overrides and the Layer Manager "Setbylayer" properties - I played with both Color and Transparency and watched a BricsCAD YouTube on this topic.
COMMENT
I DO NOT understand why I had to resort to opening the attached file independently and changing properties there: I also detached / re-attached this file.
Then, it showed as Color 9 in the file to which it was attached.
I appreciate any related input.
Clint
Best Answer
Answers
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
