How to update all or some Sections
fs_at12
edited January 2020 in BricsCAD BIM
Is there a possibility to select some or all sections to update?
now I am struggling a bit, updating 30 Sections one by one.
  • Louis_Verdonck
    edited January 2020
    In the Structure panel click the Sections node to select all sections then choose BimUpdateSection in the Quad. See movie.
  • To select a set of sections, expand the Sections node in the Structure panel. Press and hold the Ctrl-key when selecting sections or section groups (e.g. Elevations, Plans, ...)
  • Thank You Louis!
    This is what I was looking for.
    In the project browser, the Shetsets don't change the "out of date" status after update
    its a bug?
  • I have same experience of them not updating
  • Can someone answer this, I have same issue and sheets will not auto update after folliwng this method
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
