Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Extrude a rect also did a subtract - how to prevent it?
I extruded a rectangle (yellow) and the extrusion passed through an existing solid (green).
What I thought I would get is an interference pattern as a visual clue but the action did a subtract on the existing solid. All 4 pieces of the angle iron base were identical before the extrusion. Now two have cuts in their vertical sides.
I checked the EXTRUDE docs and saw no reference (that I understood) to change the behavior to not subtract, but to interfere. Is there a setting?
  • You need to set DMEXTRUDEMODE and PUSHPULLSUBTRACT to your liking.
    I guess the most intuitive setting for the former is 6, and 0 for the latter: This will allow you to DMEXTRUDE boundaries that lie on a solid's face to create holes or protrusions, without having to fear that you might alter other solids encountered on the way, and the same would apply if you DMPUSHPULL recognized boundaries.
  • Thank you. I'll look those setting up.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
