SketchUp vs bricscad... Shape Bender
Anyone knows how to do this in bricscad??? I used to love this function...
https://youtu.be/Dcdx1Ab1SWM
  • Get the profile(yellow) of the wall and sweep it along any path curve(red) using the SWEEP command.
    As for the windows you can construct one vertical row (3 windows) in Z direction, create a block
    and insert the block along the path curve using the DIVIDE or MEASURE command with the insert Block option.
    MEASURE
    Select entity to measure:
    Segment length [insert Block]:b
    Name of block to insert [? to list]:
    DIVIDE
    Select entity to divide:
    Number of segments [insert Block]: b
  • Thank you for this. However, with shape Bender you call create ie a wall with windows, things, holes, for knobs etc... Then grab the entire entity and Bend it to any angle 0-360°
  • Transform Curve or Twist ?
    (Modeling : Direct Modeling : Deform : ...)
  • Ok I'll try that
  • Will likely work for a single Solid only ?
    Never tried these Tools.
  • @Anthony Apostolaros can you figure this one out?? LOL ;-)
