Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
BricsCAD Platinum Civil, TIN Surface Issues
When creating a TIN surface from polyline contours, by either Breakline or Points, I get significant deviation in the resulting tin surface.
This is evident when I overlay the original polyline contours with the created TIN Surface contours.
When I try TIN Edit to correct the deviations I cannot;
1. Select the extra TIN Contours created during the TIN Surface execution to delete them.
2. Modify the TIN Surface contours (Breaklines) by adding new polyline breaklines over the neglected segments of original contours.
Any suggestions would be appreciated.
Thank you
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
